1 - 2 of 2 Posts
so i finally decided to do my head gasket and put my semi built head on with edelbrock intake manifold and hondata intake gasket. so after i installed it all and fill the fluids, i see some coolant leaking. it looks like its leaking from the intake manifold. i have never used a hondata intake gasket before but i do remember seeing in instructions to block something off if necessary and i threw them away. is there a special way to install the gasket?
See above...
Nope, no special way. Are you sure you torqued those nuts down in sequence and to spec? I once had a brand new IM gasket not seal and the coolant poured into my #4 CC and caused the motor to blow a HG too. Expensive lesson!
1 - 2 of 2 Posts
