1 - 4 of 4 Posts
Hello plp. will this product worth the $$$? Let me hear your opionions...
  • Extremely efficient at reducing fuel temperature for a denser air-fuel mixture
  • Advanced heat sink design decreases fuel temperature 20% over other cool cans
  • Tough polyethylene outer shell will never rust, and has a higher insulating value than cork to make ice last even longer
  • Internal aluminum parts are designed for lasting service and engineered to be compatible with today's high output fuel pumps
  • The inlet and outlet are 3/8" NPT, so you can attach any fitting and use any line
  • Lid is held on by a wing nut with a closed-cell foam seal between the lid and can
  • NHRA approved mounting includes two stainless steel straps with T-bolt clamps and lightweight aluminum mounting bracket
  • Spacing of steel straps aligns perfectly with mounting bosses molded into the Super Cool Can housing for super-strong attachment
  • Approximate dimensions: 7-3/4" x 7-3/4" x 8" tall
NOTE: Not recommended for high-pressure fuel injection systems
1 - 4 of 4 Posts
