1 - 15 of 15 Posts
i saw how to do it on this site somewhere but cant remember where and cant find it again but...
how do you convert the psi results of a compression test into an approx compression ratio??
FF Misfit
Bump, I wouldn't mind knowing how to do this for when I get my H23 done.
FF Misfit
Thanks for the info. Hey Bone you wouldn't happen to have a more specific # to add would you?
D-series Janitor
Its really tough to say given valve events play such a huge part of dynamic compression. Its why there is a difference between static and dynamic.
With that said, I have found that closer to 17 is about right.
i believe bones was the one who posted it the first time i saw it.
FF Misfit
Thanks ya'll. Since I'm building a H23 w/ Type S pistons it's really hard to get the exact #'s on what my CR will be so this is good info to have. :TU:
you could always CC the head, then the piston and know for certain
cranking psi cannot give you any info on the compression ratio.
Lets see, same motor, same cam and everything.
Test 1 = 175-180
Test 2 = 195-200
Test 3 = 155-160
Test 3 made the most power.
Wanna guess what I did?
FF Misfit
Test 1 = 175-180
Test 2 = 195-200
Test 3 = 155-160
Did you put oil in the cylinders?
1 - 15 of 15 Posts
