1 - 2 of 2 Posts
Accord CG7
Hello.
I have the above vehicle with a engine d16b6 non-vtec.
The engine has 400,000 kilometers. Here in Greece you can not easily find spare parts for the particular engine.
Has anyone done this particular conversion to that particular model?
As soon as I've searched for it, I will need engine mounts, motor bracket and control unit from Civic 92-95.
\/Your Mom Was Here\/
Vibe GT
You should be able to use your existing mounts and brackets and put them on the new engine with no problem. You will need the ECU for the engine and it looks like you will need to wire for the VTEC as well. You may need a different o2 sensor as well.
1 - 2 of 2 Posts
