1 - 4 of 4 Posts
crx
for soem reason my car runs bad with the O2 sensor hooked up.
when i was runnign my A6 head and OBD-0 setup it woudl get a nasty sputer and boggy feeling under low throttle. now that i have Z6 head and OBD-1 setup it still does it, even with a new O2 sensor.
could the far down placement of the O2 sensor on the dc sport header cause this?
i even ran my own wire to the ecu.
crx
my obd-1 ecu is chipped to run a single wire O2 sensor. this problem is weird cause it did it with obd-0 and obd-1 so i know its now an ecu problem or wiring problem. all i can think of is it being the placement of the O2 sensor in the exhaust.
1 - 4 of 4 Posts
