1 - 16 of 16 Posts
H
I have a 1998 Civic H/b, I put a 2000 Civic EX engine in and kept the DX wiring harness. I just picked up a 2000 Civic EX computer and a harness to change OBDIIA to OBDIIB and to use the EXs full potential (along with V-Tech).
I plugged the new computer and harness in and it is doing something weird.
At idle, it pulses from 1500 to 1600 Rpms, and when I give it gas, it only goes to 5000 Rpms.
Does anyone have a solution to my problem?
Please?
[email protected]
thankx
H
i love my SOHC
Half the price
Half the work
More fun
H
someone said something about the IAC is different
is that true?
it's most likely your IAC valve... your DX had a 3 wire unit. The EX manual has a 2 wire unit. So probably your DX harness is wired slightly wrong for the EX computer.
H
how would I go about fixin' this problem?
should I cut a wire?
H
i have the wiring harness from the engine I put in, 2000 EX, but it is cut at the fire wall. would this help me at all?
i already told you the things you have to wire up in the other post you made about the same question .. iacv, vtec solinoid, vtec pressure, knock sensor, and maybe some other stuff.. yes the old wire harness will help you because it should still have the plugs you need and the wires and all you have to do is add them in and wire them in at the computer.. compare the dx wire harness to the ex and you will see what you need to change
H
thanks for all your help, I'm going to check the codes tomorrow and try to get this all figured out.
any more help will be very helpful
thanks
H
yes, I'm sure.
the car runs fine with the P2E computer in it.
H
i have everything i need to know thanks everyone, I'll be doing it all as soon as it stops snowing here in jersey and I don't have to plow anymore.
can't beat makin' some cash.
H
Discussion Starter #16
Mitch that would be great.
It shouldn't take that long.
I have everything, just the time thing is bad.
I have the OBD-IIB computer, and a conversion harness from Boomslang.
I also have an APEX-i VAFC to put in.
I don't have any of the little pins to re-pin the computer, if I need them.
I just need the time and the help.
How's Sunday July 31 for you?
My girlfriend is going to the shore and I am alone all day.
If that doesn't work out, I am off on Wed. and Sun.
Do you still want to go see Rob's shop sometime?
If so let me know, we could meet up and cruise over there.
Later.
Pat
1 - 16 of 16 Posts
