1 - 3 of 3 Posts
I'm somewhat new to reading and plotting maps and while looking at a TDO5H-16G(big) map I got to thinking, does it matter what turbine is used?
I plotted the big 16G and with the boost on the low side it would go into 60% at higher rpm's. So I raised the boost and dropped the rpm, which puts it at 68%.
I wanted to plot the Super 20G but I can only find maps for the TDO6H-20G, but the turbo I'm looking at has a TDO5H-10CM2 turbine. I know that helps it spool faster so it has to change the map, right?
10psi at 2250rpm, 12psi at 3000rpm. 8k at first then plotted 7500, I plan to let the dyno tell me where to set the red line but those are great starters.
Retired From Hondas
Squirrel Performance
your turbo should be n the list.. Fill out your specs and info and compare your work
1 - 3 of 3 Posts
