1 - 6 of 6 Posts
Boost Gets You Laid
Del Sol
So before I parked my car and pulled the motor I did a compression check.
Starting at distributor side:
200-182-182-185
Haynes says some crazy shit like carbon buildup on the valves or w/e.... but the thing is, the head is clean as hell. There's barely any oil varnish in the top end, intake runners have no fuel varnish, and the valves look new.
I also had a small intermident missfire at idle... like it would idle fine, then miss once and then go back to normal. Car still pulled like a raped ape and throttle responce was great.
Any ideas?
honda/firebird form.
Inside the combustion chamber. That's what the Haynes is refering to. #4 is a bit high. That's odd.
Check your plugs and gap, cap and rotor, and plug wires.
whats that have to do with the compression numbers?
and whats the timing look like??
He is referring to the miss fire.
gotcha.. yeah a bad wire, will ground its self out, and sound like its missing... and or plug gap and rotor could be the culprit also...
Boost Gets You Laid
Del Sol
I planned on all new tuneup stuff. NGK plugs, NGK wires, Beck Arnley Cap/Rotor, Honda Fuel Filter. Plug gap was like 0.040" Mechanical timing was dead on.
I'm also going to re-ground the motor with some new chassis grounds.
But yeah, the high compression #'s on the 1 cylinder kinda concerned me.
I too found the secrete of the failtastic h22 timing belt tensioner. That bastard is bolted on to the waterpump and it's only like 4threads deep.... needless to say I broke that motha when I took it apart lol
1 - 6 of 6 Posts
