I searched for this but didn't find it.
It is probably different for every motor and depending on other mods but:
How much increase in horsepower will a motor see from (X) amount increase in compression?
:TU::TU::TU:the only thing that comes to mind was rulle of thumb 3-4% gain in hp AND tq per full point of compression increase.
Alright thanks. I couldn't find this infor anywhere, and didn't know if it was a dumb question.the only thing that comes to mind was rulle of thumb 3-4% gain in hp AND tq per full point of compression increase.
9.2 to 13.7 compression.......
I'm at 130 whp, that would put me at 148 whp (dynojet) and ported head should bump me to 155-160 whp, it not more!!!!!!!!
My goal of 145-150 whp D15 is not out of line........
i dont think you can run pump gas with 13.7:1...Alright thanks. I couldn't find this infor anywhere, and didn't know if it was a dumb question.
Is 13.7:1 safe for everyday driving?
Not quite. Static Compression is like 30% of the equation, if someone tells you just by static compression if you can run pump gas, they probably either don't know what they are talking about or don't feel like taking the time out to know all the parameters first.According to most of the big name tuners, running much over 12:1 on a street engine has diminishing returns. You have to pull so much timing to run pump gas that you'd make the same power with lower compression.
screw the tuners, talk to the engine builders..........According to most of the big name tuners, running much over 12:1 on a street engine has diminishing returns. You have to pull so much timing to run pump gas that you'd make the same power with lower compression.
with all this talk bone youve got me considering throwing some pistons in my motor.... lol
I prefer to stay with Honda engine builders and tuners. It amazing who you can talk to on Honda-Tech.screw the tuners, talk to the engine builders..........
Have you read who won the lastest Engine Masters build-off?????
http://www.popularhotrodding.com/enginemasters/challenge/2006/0610em_challenge_results_friday/
Wanna guess who's been helping me?????
Next week Tony's moving his shop to St. Leon, IN......needed more room.
