allwheeldriveturboboxer
'08 Mazdaspeed3
i did a compression test, hot engine, PowerFC disconnected and WOT, 7 cranks, and my numbers were 240-245-245-245...so, i do the 240 one over and over, 7 cranks each time, and it is like 240-235
...so, i then take literally ONE THREADS worth of oil, put it on the threads of the comp. tester, screw it in, and its now 245 everytime; without fail, itll hit 245+ each time but before the literally one/2 threads worth of oil on the threaded end of the comp tester, it was 235-240
Harry aka Ndcissive said it is possible there was a slight leak around the threads of that cylinder, however, I did screw it in rather snug... Ever seen this?
i have noticed higher numbers when i put oil on the threads on the tester.. i put oil on the threads and mine has a rubber seal i lube up to.. i relube it for every cyl so its even... there is only a few psi difference that i have noticed when i dont use oil on the threads... i also unplug my injectors... numbers shot up 15+ psi when i unplug them...245 kicks ass man.. mine is from 185-210
S
Because 1 and 4 are the same? Or they are with in a few percent of each other
Sorry but..
" I declare shenanigans.....get your broom"
For those of you still watching south park
