1 - 11 of 11 Posts
I have a crx si with a minime (a6/z6) and id just finish doin the compression test and this are the result:
cylinder 1-215psi
2-210psi
3-215psi
4-210psi
What u guys think?
I think if u r 20psi different u might check ur piston rings or head gasket.Btw i have 155k on the block and 77k on the head using a d16y8 head gasket.
I also have a cool title
I wanna do a compression test im a total n00b(hence the name) when it comes to working on my engine. What do u mean by crank it four revolutions?
I mean the piston needs to compress four times(so move up and down four times)
Buy a copression test at the auto part (they are like $25.00).Unplug the sparkplug wires and the spark plugs.
Desconnect the fuel pump
Put the Compression test in the #1 cylinder and crank the car 4 times or till the gauge dont move anymore.Repeat this 3 more times.
Put everything back 2gether.
Show us ur results.
cylinder 1-215psi
2-210psi
3-215psi
4-210psi
What u guys think?
Hi Rick, what sort of compression ratio are u running on yr engine set-up with those readings??
cylinder 1-215psi
2-210psi
3-215psi
4-210psi
What u guys think?
210-215 is normal for a mini-me swap, careful on the gas and timing with the added compression.
1 - 11 of 11 Posts
