1 - 7 of 7 Posts
Same as above
The engine:
D16z6 block
Oem bearings
Oem oil pump
Fjt 138.56mm rods
76mm vitara pistons
Arp headstuds
Head:
D15b head
D15b cam
D16y7/y8 cam gear
Timing and idle is dead on.
Compression test results are #1-150, #2-180, #3-120, #4-180.
Im getting ready to open it up but just curious if there's possibly a less serious problem than blown out ring lands that could cause the difference in compression. Should i look into valve lash or a blown head gasket first or just proceed with pulling the pistons out?
It doesnt burn oil. Just a few drops of oil in the catch can. Smokes a bit from the valve cover. Doesnt overheat.
Okay, did a second wet compression test increase the numbers?
Leak down?
Valve lash unlikely to only effect 2 cylinders, but anything is possible. Unless you have reason to believe you did it wrong or just did a valve adjustment, it would be far down my list. Well dependent on what a wet compression and leak down showed.
Without a wet compression and leak down it's a guess as to what the problem is.
Same as above
Wet compression test increased numbers. But oil will plug any small leak right? Weather it be a small gap between the valve and head, head gasket, or rings right? Does the severity rule anything out? Like the 60psi variance?
Also plugs looked fine light brown and dry.
95 ej2
The oil will be forced down into the rings though and as long as the numbers go up your rings should be good but a leak down test is faster then trying to guess all the rest.
conventional theroy if your compression number go up with oil you have a lower end sealing issue. A leak down is going to be the more conclusive.
compression = quick easy lets you know there's a problem. Leak down tells you where.
I dunno I trust something this important on HF. I personally would be using mac, matco, or snap on. Don't get me wrong I have a lot of HF tools, but I'm not going to trust there tools for something as important as the cause of low compression.
1 - 7 of 7 Posts
