1 - 17 of 17 Posts
Crx
last night at the race track i decided to try a stock y8 cam in my combo,
so i made 3 passes on the comp switched it over in the pits and made 3 passes on the stocker
here is the 2 best passes for each
comp stock y8
2.4950 60ft 2.4121
6.7809 330ft 6.5791
9.6140 594ft 9.4009
10.2521 1/8th 10.0431
70.52 mph 70.06
the comp was dyno tuned while the stock cam was just thown in and ran
Crx
yes the car was dyno tuned for 5 hours with that comp cam in it and it had an adjustable cam gear on it so we tried every degree range because it never made any numbers that were anywhere near respectable , the car has seen nothing but 93
octane for 4 years now
oh and btw the car went a 9.95 1/8th the next night after i had access to my timing light.
yep.. like i said in my rewiew ! it make alittle on top at 4 DEGREES !! but low end seems more weak...
i got 4 HP over the stock Z6
Crx
Zeus, what you said would explain why my car acted the way it did with the comp cam using an auto and stock converter, i need those few horsies down low to get it moving that the comp cam takes away.
24-7,takes me 15 minutes to change the cam in my sohc motor, and the crx weighs around 1600 lbs, there is no way in hell that there is 2 tenths left in weight reduction
Haha, sorry the weight was not mentioned.
yep !.. before i made 132 at around 6500 RPMK now i make 136 at 4 degrees at 7000 RPM.. but lost max tq.. just holes the top end alittle longer = alittle more HP way up.. mine is makin fair power 2 about 7600 RPM..
comp stock y8
2.4950 60ft 2.4121
6.7809 330ft 6.5791
9.6140 594ft 9.4009
70.52 mph 70.06
great thread for us auto guys. currently running the stage1 comp cam 12:1c/r auto. been wondering if it was the weak link in the eighth.
btw, we talked about this on the other forum. i can really see the weight difference in your crx vs. my ek just by looking at the 60ft.'s i've run some 2.3 60 fts and still end up with a 10.7 e.t. in the eighth. just amazing.
have you the 59300 cam with your y8 cam gear?
i was driving around today with zex cam in my auto y8 and just knew this is what is killing the power. i know b/c the fastest my car ever ran all motor was with a stock bottom end and a stock z6 cam timed correctly with an aem cam gear. when the motor was rebuilt i hadn't figured out that i got sold a z6 cam and put the stock y8 gear back on. first time to the track after the rebuild and the z6 cam a half tooth retarded, i duplicated the same e.t. that the car was running before the build. now with the y8 zex cam i'm just barely getting within two tenths of that time. i just bought a z6 cam and z6 gear off ebay to go in y8 so it'll be timed correctly. when i get some timeslips we're going to know a whole lot more about automatics and camshafts. (keep in mind i have the 105100 in my 12.1:1 y8 auto)
I have the same cam and I love it, it makes great power
1 - 17 of 17 Posts
