Plans as follows:
* D15B7 SOHC Engine
* Greddy 15G Turbo Kit
* Front Mount Intercooler
* Greddy E-Manage w/ Injector and Ignition Harness'
* 2.5" Kteller Down-Pipe
* 2.5" High Fow Cat
* 2.5" Magnaflow 22" long resonator
* 2.5" Inlet Greddy Evo2 Replica Muffler
* 500cc DeatschWerks Injectors
* Crower Rods
* Stock FPR and Fuel Rail
* DX Transmission
Vitara Pistons
D16Z6 Head Gasket
D16A6 Cam
D16Y7 Cam Gear
New Exeddy OEM Clutch
Ported Throttle Body and Intake Manifold
Walboro 255 Fuel Pump
* = I already have this part.
I'm working hard on my crank ventilation setup... it will use exhaust slash-cut vacuum and I'll have two 3/4" outlets (need to make these), one 1/2" outlet (already made this and found out it's not enough), and the factory breather outlet running from the valve cover to my homemade baffled can.
Am I missing something? I will be getting this tuned professionally... does anyone know if Greddy would send me a base map for this? Presumably I can't load the base map myself since I don't have the support tool... so I would towe it to the tuner -- presumably it would be safe to drive up onto the dyno at least? It has a tune in the computer for the bone Stock D15B7 with stock injectors, exhaust, etc -- I had it tuned before I decided to build it up more.
Thanks in advance for helping me out!
* D15B7 SOHC Engine
* 2.5" High Fow Cat
* Crower Rods
* DX Transmission
Vitara Pistons
D16Z6 Head Gasket
D16A6 Cam
D16Y7 Cam Gear
