the o-rings go between the sleeve and the shock body. the set screws hold the sleeve to the shock body. the flat gaskets go between the spring and the upper perch and the spring and the lower perch. use the correct size o-ring to fill the gap between the sleeve and the shock body.
nate - happens to hate this type of sleeve system coilover and strongly prefers the koni specific ground control sleeves used in conjuction with koni's or the koni branded sleeves in conjunction with koni's. cheap stuff is cheap for a reason...
