I installed my front coilovers today and found out the adjusting ring on the passengers side coilover doesn't tighten all the way and can be turned when there is no pressure on it but can't be turned when car is on the ground. Do you think it will still be driveable until I can at least replace the ring?
Discussion Starter · #4 ·
well the well or whatever you call it, that the tightening screw goes into is shallow so it doesn't go in all the way. I fixed it though by filing the screw down enough for it to tighten the collar all the way.
