1 - 2 of 2 Posts
DROP IT LIKE IT'S HOT
2003 Civic Si
I got a d16z6 with cai, headers, custom exhausht, external coil, new wires, and Denso irridium plugs. Drives fine but i get a code 15 after driving the car for a while. I turn the car off and it goes away. How can i resolve this problem.
M
Get a haynes book for the car. it tells you step by step how to reset the ecu and clear all the codes out and also tell you what that code means... In my car (95 5 door )it means ignition output signal. check the ignition system.
if that helps any. You can get these books at autozone for like $20.
They really help. I basically learn everything off of this book.
1 - 2 of 2 Posts
