1 - 3 of 3 Posts
8
Could use some help on a clutch update. I am going to upgrade my clutch on my 88 CRX si with a D15B to a stage 1 90-91 clutch. I am also upgrading the to a lightweight Flywheel. Is there anything else I will need other than the Clutch Kit and lightweight Flywheel?
Thank
88REXer
what tranny you using? If using the 88, the 90-91 clutch isn't gonna fit.
You'd need a 212mm Prelude clutch, 21 spline
8
clutch upgrade...
sorry for my ignorance but the 212mm predule clutch is different than the clutch kit for the 90-91 CRX? This is what is included in the clutch kit I want to buy:
Pressure Plate
212mm, 21 spline Disc
Throw Out Bearing
Pilot bearing
Alignment Tool
8lbs Chromoly Racing Flywheel
1 - 3 of 3 Posts
