1 - 4 of 4 Posts
Sup my fellow honda techers!..
Alright so let me break down.
I have a 1992 honda civic si hatch..
single cam zc v..
I recently replaced my clutch about a year ago.
Anyways about a week ago i was parked with my
car on.. I had it on neutral and all of sudden i felt my
clutch pedal sink to the bottom. so i pumped it and it
regrabed and everything was all good. 5 minutes later it
does it again. So i checked the cables and fluid.. it had
no fluid so i figured i just needed. it was leaking from
the front headers side (slave cylinder area)...
SO i went and bought some fluid. i added some and pumped
my clutch and no luck!> so i figured it was time for some bleeding?..
after two bottles of fluid and bleeding still no luck..
So me and my pops replaced the slave cylinder(where you bleed
the clutch from).. and still no luck.we took of the master cylinder and
checked it and its in working order!...
THERES NO VISIBLE LEAKS. WHEN WE BLEED IT IT DOENST
LOSE MUCH FLUID
i know its not my clutch!. its been working perfectly with no
problems.. any suggestions?
1 - 4 of 4 Posts
