1 - 2 of 2 Posts
I have a stock 94 civic ex (d16z6) that I have been having some clutch problems with lately. Twice this last week I have had to bleed the clutch because it has been getting an air bubble in the fluid some how. When that air gets in there the clutch will totally stop working. What do you guys think the problem is and how can I fix it. Thanks
you're probably leaking fluid somewhere. Check all the lines in the engine bay for leaks... when you find it, it probably will be at a joint.... replace the o-rings or whatever they use for gaskets. Probably need some teflon tape for the threads, too.
1 - 2 of 2 Posts
