1 - 6 of 6 Posts
Honda
Does anyone know a good write up a could someone make a write up on how to replace the clutch master cylinder?
any help would be greatly appreciated
thanks
Honda
transzex said:
drain, unbolt, bolt, fill, bleed.
what is the easiest way to drain it, just unscrew the bleeder valve and pump the pedal?
thanks
get a vaccum pump with a resivor on the line.
I would suggest bleeding it before installing it.... but thats up to you.
1 - 6 of 6 Posts
