1 - 12 of 12 Posts
You don't have to take the axles out of the car though, just undo the lower ball joint and swing the hub out pulling the axles with it. I have a stuck axle nut on one side so I just did that and it worked nicely.
its gonna be easier to
un bolt your axel nut
un bolt your lower ball joint, your spindle from your camber, and the ( forgot the name ) to the right. it moves the spindle
pull your axels
put a jack under the motor, unbolt your tranny ( and anything attached). get under there and big boy it out an you got it.
its easy an wont be nothin to put back together this way.
pull your axels
What he said with pictures
http://www.d-series.org/forums//showthread.php?t=14079
Worst Mechanic Ever!
Triple check your bolts, a lot of people miss a bolt and can't get the tranny off the block. :D The starter bolt got me the first time I pulled my tranny.
Take both out. The transmission has to come completely out as well.
tranny doesnt have to be completly out. its just way easier if its completly out you dont have to use a hillbilly impact aka a hammer and a openend wrench.
1 - 12 of 12 Posts
