I finally got the 95 sedan. But it needs a clutch and its has a b18a1 in it. My question is how do i determine what year the motor is so i can buy a clucth for it. I am an idiot at this. THanks for the help
You need to determine if your swap includes a cable or hydro tranny, and buy the clutch based on that. All B-series clutches fit all B-series engines/tranny's as long as you keep the cable/hydro thing straight.
If you have a clutch fluid reservoir, you have a hydro tranny.
i do have a clutch resivor and i know it is a hydro tranny... but i just want to be certain i buy the right clutch, because i think there is a 220 mm and theres a 222mm? i think.... the 90-91 are different with the throw out bearing than the 92-93? so i was just wondering?
If you have a hydro clutch, then you just need to worry about '94-'01 B-series clutches, which are all the same. Sounds like you have a '90-'93 engine with a '94+ tranny.
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
