1 - 16 of 16 Posts
1996 civic si
so its my first time doing a clutch, i got it all apart, and i gotta put to together now,
i dont got a clutch key, but ima go get one tonight,
i was wondering if there is a way to do it without one tho ?
and if somone can post pictures to help me like with lining it up cuz i got no clue what im doin aha, ima n00b fo shooo,
thnx
1995 civic hatch cx
I had the same prob my fist time installing clutch i lined it up using a socket but i can get the tranny on. Does anyone know if canadian tire sells them?
1996 civic si
i took the clutch outta my buddys car, stage1 6ppuck 6 spring, liek 300km on the clutch, i got it for 150$. he blew a rod threw his block . but he dont got the key he lost it.
You were born with either 10 or 11 clutch keys, some freaks got 12 or 13.
I MADE my second alignment tool fro an old mainshaft.
1996 civic si
chk this aha, i left the pressure plate loose, put the tranny on, bolted er all up,
threw the starter hole i just tightend the pressure plate down, i hope it works, aha
got a few more bolts and she will be runnin..
now i just gotta figure out how to put a new lower balljoint in aha
See above...
^I guess one could do it that way...yet you run the risk of the PP becoming misaglined from the clutch disk.
98 Civic CX-T on E85
did you just tighten them down, or did you actually torque them to spec?? sounds Sketch to me...
99 integra ls-DD
i dont think they are too expensive to buy one, auto part store might have one. check around.
I've done it through the starter opening before.
Customer had a clutch installed as a local shop and complained of a rattle. They blamed the tranny.
I pulled the starter and one PP bolt was missing, the other 5 were loose. Lucky the missing bolt was able to be fished out once clutch dust shield was removed.
Easy $100 fix.
when i did my swap i didnt have one so i used a socket with electrical tape wrapped around it, it took fucking forever and was a huge pain in the ass but i got it on there and worked just fine
1996 civic si
i dont got a tourqu wrench so u just snugged em up.
but i hope what i did works aha, car should be on the road by tomoro, ill let yuh guys kno,
They call me Awesome!
This is a bad plan. Beg/Borrow/Steal a torque wrench and do it right.
1 - 16 of 16 Posts
