The clutch disc is likely on backwards, and the shift arm is likely bent, if you bump the shift rod before installing the interlock guide bolt it can come out of alignment and the bolt can catch an edge, just a tiny bit is all it takes.
The clutch disc was installed the right way around, it had a side marked saying "transmission side" which was set facing the transmission and I even compared it to the old clutch which had a "flywheel side" marking. With the interlock guide bolt I checked the clearance in the hole before threading it in and there was 0 resistance the whole way in.The clutch disc is likely on backwards, and the shift arm is likely bent, if you bump the shift rod before installing the interlock guide bolt it can come out of alignment and the bolt can catch an edge, just a tiny bit is all it takes.
I honestly can't remember if there was a washer but if there was it 100 percent would have been reinstalled with it. The clutch cable is brand new oem and the pressure plate is a brand new exexy oem replacement along with the clutch and throwout bearingDid the interlock bolt have a sealing washer on it when you pulled it off? I think some of them came with bent shift arms, and the washer was put on there to remedy the issue. ive pulled several apart that had that stupid sealing washer on there only to find the shift arm bent, with no evidence of the cases ever having been opened before. Also depending on the pressure plate and the clutch cable I've seen them stretch a fair amount before the clutch would disengage.
yes i have, brand new clutch cable since my old one was shot, can get it within adjustment but it still wont disengageHave you tried adjusting the clutch cable? Maybe its not pulling the throwout bearing arm enough to fully disengage the new clutch?
no IGB had a washer....Did the interlock bolt have a sealing washer on it when you pulled it off? I think some of them came with bent shift arms, and the washer was put on there to remedy the issue. ive pulled several apart that had that stupid sealing washer on there only to find the shift arm bent, with no evidence of the cases ever having been opened before. Also depending on the pressure plate and the clutch cable I've seen them stretch a fair amount before the clutch would disengage.
i just replaced em since some of the old ones were gashed up and it wasn't much more expensive over ordering stock bolts onlineThe is no need for the ARP bolts. Just red loctite with an alum. flywheel.
At one time ARP was using B series length crank bolts whih would rub on the rear main seal holder enough that the starter couldn't spin the motor over.
The stock bolts are good for over 425 crank horsepower.
People throwing $$$ at D parts that would have been better spent elsewhere.
Also with some setups the clutch system can over travel causing the PP fingers to grab the flywheel bolts. THat is when a clutch pedal limiter comes into play. When the over travel happens, try not using all of the pedal stroke to get the clutch to disengage.
