1 - 12 of 12 Posts
I've been searching for hours with no luck, so I'll just ask...
Does anybody know of a clutch disc that is 20 splined, but has a smaller diameter, like 190??? I have an old lightened ZC flywheel here and I'd like to use it with my 89 Tranny...
Thanks
88 CrX Si
transzex said:
I've added to Dave's sometimes incorrect info.
You can run a 200mm clutch on a 212mm PP/flywheel.
but can u run a 190mm with a 200m? no right? The 88 tranny is the most trouble some tranny... becuase with that information i have there at that web site... theres no other clutch i can use... other than the 88... i mean i cant just slap on another fly wheel to make it work, i gotta buy a 89-91 ex or si tranny and flywheel to at least get away from the small clutch i have in my 88.
Yes you can run a 190mm with a 200mm. As far as the '88 trans is concerned it has 21 splines. If you want you can run a 212mm setup with an '88 trans by getting the 212mm 21 spline disc for a 84-87 2.0L prelude. I did this for awhile works great!
BTW this might help you keep it all straight
http://www.d-series.org/forums/showthread.php?t=35
88 CrX Si
Beautiful....i think im gonna try that
1 - 12 of 12 Posts
