1 - 20 of 22 Posts
If it were me, I'd do this
1st = 3.25 (STOCK first gear, no need to replace this)
2nd = 2.4
3rd = 2.0
4th = 1.66
5th = 1.4 (while having the option of several factory 5th gears)
and use factory final drives.
K2e2vin said:
I'd like a taller first gear so that ALL the gears are crossed/close ratio. IMO the short first gear is for driveability.
yup, the d15b8 was able to get away with it, and so did the d15z1. both being sub 100hp motors.
Clutchmaster said:
I'd like 4.30 final drive even though mine is like 4.25 already
:confused:.....ah well.....:alky:
I'd like(P.S.- I have an EF, so cable gearing for me :p):
3.250 - stock Si
1.944 - stock DOHC ZC
1.565 - Aquafina
1.150 - custom(not exactly that, but whatever would be a good 3-4)
0.694 - stock HF(for highway)
Stock 4.25 FD
transzex said:
2.75
1.75
1.35
1.05
.700-.800
4.5-5.0 FD depending on tire size
where can I buy an 4.5 or 5.0 finaldrive?
I'm not a sponsor and I'm not advertising. I just posted up about the gear set. Anyone can do that.
Sounds like it to me by your post.. Edit your wording if you are not promoting.
1 - 20 of 22 Posts
