Is there a write up to put a hatch or sedan entire climate control, heater and all into a vex. I just got a vex without any climate control and I need my heat it gets cold
any 92-95 civic climate control should swap over i would think, im not familiar with those years i know 96-00 have one style climate between 96-98 and another between 99-00.
talks about installing ac which is the same as the heat if your missing the blower.
As far as the control box goes your have to match the yrs. The 92-95 will have slider for the hot/cold while the 91 and under had a turn dial.
^^ Because finding a unbroken crx climate control is like finding a needle in a hay stack... I do know that the crx and 88-91 civics use the same turn dial heat/cool knob so the civic one will work for that but (I believe) the dampers on the crx are electrically controlled where the ones on the civics are slides and cables..
Yea finding a crx for that matter in the yards here are almost impossible, see I have no heater in my car at all, the PO wire tickled it and its nothing back there is there away I can rig up something simple just to get some heat , I really just need simplicity ill get pics up to show my crx
A friend of mine had one that was missing the climate control and i just used a jumper to open/close the dampers until he had the heat where he wanted it. that would work great if you still had the factory connector that the control pugged into. the hot/cold selector is nothing more than a valve out on the fire wall that turns the coolant on and off. just pull or push on the cable until the heater core warms up.
well im not looking for a stock unit my car is wire tucked and my harnnes is backing right behind my glove box so i need a smaller unit i can do my own ducking i just need heat
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
Hey all,
Long time reader, first time poster.
So, I have a 1995 Civic Ferio Vi, with a D15B (two stage vtec) engine in it. Imported from Japan, so all JDM parts.
But... Something backed off the bolt on my main pulley (AKA harmonic balancer), and it got damaged. So, now to find one.
Partsouq...
