1 - 13 of 13 Posts
1971 VW Super Beetle
I was wondering if I could soak small parts like rocker arms and other valvetrain parts in like diesel or a carb soak to clean them. Then take a wire brush for finishing and getting the more stuck on stuff. I just got the head of the z6 I bought apart and I will be having a valve job done soon. I didn't want to bolt dirty parts onto a fresh head and was wondering if this was a safe way to do it.
What about sensors if they're really dirty in the head obviously I can soak them because of the plastic and electrical in them, but I can spray them with something and brush off anything especially bad. Would carb cleaner be a safe spray to use?
I did do some searching but the words I used I guess were not the best or something since I didn't get the direct answer I was looking for.
98 honda civic LX
why not use de-greaser? a little more fire proof and you can rinse those parts off with water then soak with wd-40.
I used Chem-tool b12 in my fuel system for my bug a lot after I freshened up my carburetor and re-jetted it since it had varnish and stuff building up in it. I took the top of the carb off to reset the float while tuning and the inside of the carb was spotless.
I think I'll do the chem-dip and after reading you didn't do more than shake the can once and they came out clean then that is what I will do for the rocker arm assembly and stuff since the head will be cleaned by the machine shop.
Meat Popsicle
91 CRX Si
You might have to wipe them off with a red shop rag or something but very little agitation is required.
I used it for my rocker assembly.
Before:
After:
Before:
After:
My head basically is that same brown color. Somebody wasn't too good about changing the oil apparently
Meat Popsicle
91 CRX Si
How does the rocker shaft look? If you can feel raised/depressed areas then it's prob a good idea to replace the shaft.
Don't clean ANY sensor by dipping it into a solution. IACV's and EGR valves can be cleaned with TB cleaner and q-tips. Those are the only things you might need to clean
Rocker shaft is toast, has gouges in it. All but two of the cam holders are stuck on and I have to use a mallet to tap them off. I'll borrow my friend's digital micrometer and measure the rocker arms after I clean them. It seems this motor has had many many oil-change-free miles on it. :/ You get what you pay for $120 for a z6 motor lol.
1 - 13 of 13 Posts
