1 - 3 of 3 Posts
i think my o2 is mess up because I keep getting a cel while driving. it usually come on after driving it for a while but the worst thing is that the car bogs if im in 2+ gear and half throttle. i was wondering if i can clean it?? I'm saving $$ for this sunday cause im gonna run at the track...
First reset the ECU and see if your still throwing the o2 cel. Then check for continuity between the o2 and the ecu. I not sure how to clean it, I think I read that you heat it up with a torch? What year do you have? I have a o2 sensor for sale, cheap.
I had to clean mine a couple months ago and we used carberator cleaner. It still works fine, and it cleaned it really good. (No guarantees that that's the way it's supposed to be done, but it worked for me)
1 - 3 of 3 Posts
