1 - 2 of 2 Posts
Yeah... there is a lot of stuff in there... and i also ported the intake on the TB side so its full of metal shaving.
What would be the best way to clean it. Make it soak it hot water with solvent? Pressure washer with some goo gone? Brake cleaner?
edit: the intake is out... its not on the engine
i'd say use gunk first, then wash it out with warm or hot water, then use brake or carb cleaner, then blow out all the particle to make sure with a air blower from an air compressor or something...
1 - 2 of 2 Posts
