1 - 15 of 15 Posts
pretty much like the titles says i have noticed when removing the head you get that gasket graphite embedded on the surface of the head and block, is there an easy solution to cleaning/scraping it off quickly. will need to know when i do this, i could practice on this other block i have i just need some input.
thanks in advance
i used a scraper to get off the bulk of the material and then switched over to a rotary tool with a wire brush attatchment.
lol good to see someones with me
ok good i have a dremel ill look into a slightly larger brush med/soft then the tiny one i have
If I dont have a scraper handy I will use a razor blade but always being careful and having patients.
they have special spray that also helps remove gaskets
the MAD scientist
Be careful not to damage the surface with any hard tools
I used brake cleaner and shop towels to clean mine.
that works well too, or brake cleaner and a stiff plastic brush/stiff wire brush
i save your ass when you wreck
brake cleaner ftw
i wouldnt use a razor blade. u can score it and mess it up..brake cleaner and a scraper would be best. just be very patient!
1 - 15 of 15 Posts
