1 - 3 of 3 Posts
Hello Everyone.
I´m Axel From Argentina.. I have an Honda Civic SI 1993 with D16A9 ( japaniece version )
Please, can anyone tell me the values to check the oil pressure??. the car runs perfect but I will make all services with original parts including water pump.
I afraid to replace the original Oil Pump cause here isn´t easy to get import parts and not easy to find.. so I want to check it
The car has 198.900 km ( 124.312 Miles )
I don´t know if Z6 has the same oil pump as A9.. i had a Tech Manual with the Z6 values ( 10psi Idle and 50psi al 3k RPM )
I will be vrey greatfull if anyone can give me a hand wth this
Best regards
D16A9 oil pressure:
Idle - 20 psi min.
3,000 min. rpm - 68 psi
D16A9 Oil pump:
Displacement - 67L (17.7 U.S. Gal.) per minute @ 6750 rpm
D16Z6 oil pressure:
Idle - 10 psi min.
3,000 min. rpm - 50 psi
D16Z6 Oil pump:
Displacement - 45L (11.9 U.S. Gal.) per minute @ 6000 rpm
Hi.
Thanks a Lot =)
I will check this values on mi Car ...
1 - 3 of 3 Posts
