1 - 4 of 4 Posts
Hello guys i have a problem in my civic coupe ex 1993 mt d16z6.
The electric window of the right (passenger) don t goes down
But..... if i open the driver door and then i touch the switch.... the right electric window goes down!!!
The passenger electric window dont go down if i dont open the driver door.
I don t know if i buy a new electric window wire harness is the solution. The left side i have to buy i guess
what is the code for the electric window wire harness of the civic ej1??
Thanks for all:TU:
Sounds like it's the harness that's causing your issue. A broken wire. Check the wires,might be a little hard to find.
I had the same problem. I had to take apart the harness and found some wires were rusted out. I just cut them, spliced and soldered some new wire on and my passenger window worked again.
Honda Civic and CRV
Had a similar issue with my 96 4 door. It was the drivers side wire harness in the door that wires were breaking. I rewired the entire harness with some good silicon soft flexible wire and wrapped it with sheething, to avoid cuts during door open/close. Been working perfect for over a year now.
1 - 4 of 4 Posts
