1 - 9 of 9 Posts
It's getting cold where I live and my header isn't working . I get slightly warm air but not hot like it should . Could it be the heater core or valve thats stuck? Or might I have air in the coolant ?
OEM T-stat and bleed coolant properly (with temp inside set to hot).
Also low coolant can cause your problem as well. Where was the needle on the temp gauge?
I'm going to try and bleed the coolant to see if that works . And the needle on temp gauge works fine .
too cold to drive? haghahahahahah, I sweat balls as soon as I walk outside.
1 - 9 of 9 Posts
