1 - 7 of 7 Posts
hey anyone with experience know if chrome has the availability for tuning a 2000 civic d16y7 i am looking for a cheaper rout other than s300 at the moment or where to buy the chrome chips for logs and calibration re-flash ability ??
plan on converting it to obd1?
96+ uses obd2a/b and as far as I know, you cant tune.
so you'd have to buy a ecu jumper from obd2a/b to obd1 to use a modified ecu. nope. Im obd1 and haven't quite got that far of my build.
ej2
I was wondering about that, hoping that wasn't the case , dose that involve getting a different ecu or harness setup?
do you use chrome?
If you have tuning experience (or know someone who does), Crome is fine.
I have a 272 and was street tuned on it. Not sure about converting.
I thought all you needed was this: OBD2a to OBD1 ECU Conversion Harness
Black/Green Civic HB
I learned Crome by chipping/ converting to OBD1 and having a local shop getting it pretty close for the tune, then tweaking it to run better and more efficiently on my own.
I've been a cheap a$$ though and only have a chip burner and no data logging, so it makes it a bit more of a challenge to tweak the tune
1 - 7 of 7 Posts
