1 - 6 of 6 Posts
Hi guys,
I was planning on boosting my D17 but am concerned about some chipping on cylinder 4's sleeve. I've read that this was caused by pitting/cavitation from overheating.
My goal is to push around 170-190 hp on 8-10 psi of boost, conservatively tuned. New OEM HG and ARP studs will be going on too.
Would you guys go ahead and use the block or source a new one?
I can't link to pics right now but searching Google for "chipped cylinder honda" shows what I'm talking about. Mine is minor though, one chip on cyl. 4.
why not see if it can be machined. itll up the compression a bit as well.
same
pics of said chipping. is it in the actual cylinder or on the aluminum jacket
That's not a bad idea. I'd rather minimize downtime but its cheaper than sourcing a block.
Its a bad picture but its all I have from pulling the head. Its on the aluminum jacket.
That shouldnt be a problem. I would straight edge the block.
I am confused about the title tho, the sleeve isnt chipped at all.
Sorry about that. I don't have the close-up pictures from when I pulled the head anymore. Up close, you can see on the outside edge (touching cooling jacket) of the 4th cylinder sleeve, there's a small piece missing. I don't know if that part is still referred to as the sleeve.
1 - 6 of 6 Posts
