1 - 19 of 19 Posts
Fo Do' DX daily
finally got my chipped p06 and it runs like pure crap with the IACV opened at max the whole time surging up and down
is this because of my 3 wire iavc? the engine runs so poorly i barely made it down the street
Fo Do' DX daily
im running a y8 manifold with the IACV holes epoxied shut, what year cars can i take a IACV off , im gonna go to the local junkyard but there are only a couple EK's and the one with an engine is a y7
96 hatch SIR
are you using the y7 throttle body still? car will run like crap without iac connected.
http://www.phearable.net/tech/wiring/wiring.96-98_2.jpg
That link and the 1 b4 Is helpful with the iacv repin diagram but they don't tell you that you don't have to do step 2 If your still using the y7 throttle body. The Link assumes that you're doing a full vtec swap, there's a different to us d doing only a mani swap and still retaining the 3 wire y7 throttle body.
You only need to repin it at the ecu tower and be done, step 2 is only require If you have a manual mani/manual iacv, since you already epoxy the back shut you can just run the y7 throttle body and just convert it to 2 wire iacv and not worry about finding a manual iacv. Assuming your already running the po6 ecu, you would need to repin it at the obd2a tower clip right before it plug to the obd1 adapter harness. This should be brought up In the future when people Link these write-up.
Fo Do' DX daily
well the seller i got the ecu from thinks its running like shit because of bad connections
but i think ill try swappin those wires and givin it a shot
Fo Do' DX daily
bump
just repinned the harness (moved the black/blue wire to the empty location and took the orange out) instant check engine light and idle goes up and down from 2k to about 900
99 Hatch
The same thing is happening to me. I just swapped to a PO6 and kept my Y7 TB and 3 wire IACV. My car idled high and then when it reached temp would start surging. When you did the 2 wire swap did you use the 2 wire IACV or just do it to your 3 wire IACV? For the time being I just went ahead and sealed the IACV and used the idle screw to set the idle and disabled the IACV in crome so I can get some tuning done.
Fo Do' DX daily
well i assumed i have to change over to the 2 wire iacv, i repinned the harness like i was told and hooked it up to the 3 wire and it just throws a cel and surges
99 Hatch
I'm going to try using the 2 wire IACV I have blocking the port on my z6 manifold. Right now I'm using the 2 wire as a plug and running off the 3 wire. I need to get the 2 wire connector and then wire it up like it says. The 3 wire is blocked now so I hope this works. I need to keep the Y7 TB because of the MAP sensor location. When I get the conector I'll let you know what the out come is.
are you trying to use the three wire iacv with the two wire mod? that won't work. i did the this mod on my y7auto to b18manual conversion and it works fine. but you have to use the two wire iacv from the y5/y8/si/ls/whatever else they can be found on.
but what do you do if you cant put a two wire iacv on your manifold?? doy you have to change manifolds?
'95 DX Coupe (Red)
1 - 19 of 19 Posts
