1 - 6 of 6 Posts
wheres my money man!!
ok i picked up a non scored a6 crank
bearings were not sup or anything
I have plati gauge stuff here , but rather not buy bearings and they not work
so what numbers do i compare the spec of the crank to?
Or should I just get std bearings and move foward with the plsti gauge?
I have the old mains and no rod bearings. But the mains say
well look like this so im unsure of the size of them
Lifetime Awesome Member
'89 CRX HF
My first build I compared the crank numbers to the block numbers and used the little chart in my service manual....they were WAY off
I ended up buying Honda Greens, plastigauging, and then buying bearings based on the results.
The last build i did, i just used ACL STDs, plastigauged and they were "close enough". Loose is fast ;)
See above...
Exactly what I did/do. Have STD ACLs to measure, if good then roll with them. If not, buy halves from Honda and re-plastigage it. I too let my boost build roll with looser tolerances...loose IS fast!
1 - 6 of 6 Posts
