1 - 2 of 2 Posts
I had this problem for a while...at first thought it was a vacuum leak but then it wasn't after all...had it check and it said "fuel system supply"...so im guessing something is wrong with my fuel system supply...i've change the fuel filter and used injector cleaner...but nothing yet...i thought if it was my fuel pump but no...cuz my car is still running...a bad fuel pump will not even make my car start...yet it still pulling strong..so i don't know what else to do...
the next thing i thought of was if it was my fuel regulator or fuel pressure...help me out guys...asap..
If someone could tell me how to get pdf files on the net I could give you the trouble shoot.. it mostly talks about bad connections or a bad o2
1 - 2 of 2 Posts
