ok here's my prob..
after burning a map for uberdata and putting the chip in my ecu , the check engine light wont go off.
using a crome map, everything will run normally.
is something wrong with the map, or should i do something with the flash and burn settings.
i've attached the .bin file so you guys can clarify me on this thing.
I didnt look at your map but I'll be pretty confident jumper j12 is your problem, make sure its not cut. Crome requires it to be cut, Uberdata doesn't.
If not, someone can look at your map and see whats wrong..
? If crome works use it? What code is it?
