1 - 13 of 13 Posts
when i wot in 1st 2nd and 3rd car drives fine, i noticed when im on the highway cruising in 4th and gradually step on it the check engine light comes on. I can get to read the code since it goes away when i turn the car off and start it again im puzzled have anyone experienced proplem before, Chipped computer on chrome.
Its almost like a stock computer when it reads most how it goes into limp mode, but it drives fine when the light comes on feels alittle different, i usually just flick the keys while driving off and on quickly just so it goes away.
Need suggestions ......
So don't turn the car off when it happens. Just jump the diag connector. Should still blink codes when it's running IIRC.
yeah, just keep it on when it comes on and it will start to blink for you. i had to do that on my old b16 when the vtec oil pressure sensor went bad.
I have a wideband and when the light comes on i try to see if its running leaner or richer but it appears to be fine air fuel wise.
But as far as reading the code if i turn the car off it goes away its like it resets itself
1 - 13 of 13 Posts
