1 - 6 of 6 Posts
i have just bought a civic eg with the d15b2 and the check engine light doesn't seem to be working, any ideas?
get the pin out for your ecu. The mil is a low side driver so you will need a test like. plug the pin see if the test light will turn on.
If it dose your ecu is fine. If it doesn’t you have a open wire, not power to the mil light bulb, or a bad bulb.
wtf? read above
$10 says its throwing codes and they pulled the bulb before selling the car. ive turned down a few cars cause of that shit.
1 - 6 of 6 Posts
