1 - 16 of 16 Posts
possibly ur o2 is goin bad or sumthin is goin bad but not completly broke
'02 Civic LX Coupe
Mine did that for a while after i got my headers and full exhaust installed. This is probably because i am running no cat though...
'02 Civic LX Coupe
Then that may have something to do with it. Try resetting your ECU and see what happens.
if you run a test pipe or no cat your check engine light will come on and it will throw a code that is a p0420 it says that the oxygen content is below threshold.... this means that the second sensor in your exhasut..the downstream one. is reading dirty air....obviously cause there is nothing cleaning it. you might wanna look into an o2 simulator or make your own o2 sim. this can be done by using spark plug non foulers...and dont tell me it doesnt work. people use it on turbo cars all the time. i do... and i have no problems at all
X2!!!!! Rite on the $$$$ :done: lmao
1 - 16 of 16 Posts
