1 - 6 of 6 Posts
91 ED7
Hi!
I just washed the underneath of the car.
Unfortunately the charging lamp now comes on on any rpm above idle.
I haven't got a multimeter to check voltage at the moment.
Anyone knows what this is??
Check alternator output above idle, probably fried the alternator while cleaning the engine bay.
While this is certainly possible, I have shampooed many engine bays, including mine several times, and have yet to see an alternator fail as a result of it getting hosed off. I don't take any special care to avoid getting them wet, but I also don't intentionally blast it with the jet setting or use a pressure washer.
Make sure the belt is not slipping and check all connections in the charging system, battery terminals and grounds. If problem persists, go get an AVR test done.
Check the round plug is connected all the way
91 ED7
Very wierd, it went away all by itself.
Gotta have been water somwhere.
Thanks anyway guys!
1 - 6 of 6 Posts
