1 - 6 of 6 Posts
Ok well was lookin at the canister an 1 of the nipples broke off below the hose on top that says pcv was wonderin how to remove it properly an which hoses to cap off an re reoute
iirc theres 3 hoses on it,cap two of them and leave the one for the gas tank vent open...
1991 Honda CRX
I wouldn't leave the gas tank vent open, one spark and boom! Asking for trouble. I just capped it off and been running it take way for years.
Ok lol cap off gas vent an the other 2 is there anythin else on a d15b2 I can take out I'm removin ac due to lack of room for second fan due to header. An for the fact idk if its been converted to r134
You can ditch the entire system even the canister its self and cap the line going to the canister from the fuel take if you have a gas cap that can relive pressure most obd1 cars have this gas cap stock obd0 usually don't. If you look at the system 1 goes to purge 1 to fresh air 1 to tank. The fresh air one however dose not leak fuel vapor the canister is a fuel vapor filter.
With obd0 or obd1 ecus you will receive no codes related to removing the parts. On obd2 cars they incorporated a fuel tank pressure sensor and you will receive a check engine light. Also found out your state laws on emission some time you have to have the canister installed and hooked up to pass.
1 - 6 of 6 Posts
