1 - 9 of 9 Posts
Ok so im doing my build. I have crowr stage 2 cam with the same valve springs and retainers. SHould i change my valves too? Im gonna be running like 12lb
well im shooting for at least 300hp and im gonna be running a turbonectics t3/t4
stock will be fine, unless you have a chipped head, or worn shaft....
no "real" need to upgrade them.... in my opinion, the stock valves are fine, you could have them 3-angled for better sealing and roll off of the A/F mix, but it really isnt needed......
if you have the head sent out to be P&P, then do the valves along with 3/5 angle.
Right now, just swap the valvetrain and be done.
i have a stage 2 crower shaft and crower springs and retainers. If i get the port and polish should i just clean the old valves up then?
1 - 9 of 9 Posts
