1 - 13 of 13 Posts
Hello!
I want to change my stock sleeves and put a new reemplacement sleeve for 75mm JE PISTONS with STD rings.
It's possible to put the reemplacement sleeves like darton (not MID not flanged), first take out my stock using a press tool and put the news without do machine in the block using press tool??
I don't whant to bore my block, i like 75mm standard thick sleeves.
I can't take out my stock sleeves without do machine work??
Thanks for help!
Thanks for your reply.
My sleeves are floating is a dohc zc.
Then what kind of type is this sleeve of this photo?
They are pressed or welding?(i think not because aluminium and iron can't be welding right)
If i want to change to darton 75mm ds-200-10 reemplacement sleeve what i must do?
Or i can do only honing my current stock 75mm for good rings sealing?
racist-bigot-sexist-homophob
2nd pic looks like B20 stock sleeves to me.
Well?
WAY to thick for that
Sorry nate but you're mistaken.
Taken from the parent directory of where that pic originates after he had the motor sleeved:
Well?
o shit i thought you meant they were stock sleeved b20's didnt realize that was a picture of a sleeved block, sorry
No the original pic is a stock sleeve...it's cracked. the second pic is of the same engine after it was sleeved.
honda/firebird form.
if your taking about a dirt bike lol, yes you can press them in and out, but not a inline 4 or anything of that nature
if all u want is new rings like it looks like you are kinda asking..just measure and see what the piston/wall is as of now, see how much room u have to play with
1 - 13 of 13 Posts
