1 - 12 of 12 Posts
So I was reading how you really want the oil feed/drain to be vertical. I was trying to rotate the center housing but the compressor cover keeps moving with the center housing.
Is this an acceptable amount of angle?
Do I need to loosen these bolts in the center section to clock it? I loosened all the blots on the compressor cover and exhaust side but I dont have a wrench this size.
Let me google that for you
and if you can get that bolt out, why not replace it with one you have a wrench for? or I dunno.....buy a wrench?
Googling was the first thing I did and I did not find an answer which is why I posted up here. Im not a noob at this. Ive been on forums since 2001.
Get it as close to vertical as you can. Then tighten it down to the exhaust housing. Then stick a broom handle into the compressor outlet and clock the compressor to where you want it.
nobody called you a noob. I posted a link to a bunch of links that could point you in the right direction. if youre going to get salty, should I start making memes?
lol, if you know me, I usually throw a little asshole flair into the mix, maybe a facepalm or gif. if you didn't get those, then it means I know you made an attempt lol. woosah
You shouldn't need to loosen the bolt you have pictured, just the bolts around the outer edge of the comp cover (and the ones securing the turbine housing). The chra should be able to rotate independently from the housings once both are loosened.
You don't want any more than 15 degrees off from vertical for the chra and if you have to use a small amount of tilt, I would try to angle it so that your gravity drain isn't fighting inertia when accelerating.
ej8
Do not lossen any of the 4 bolts on the center.
Only lossen the 5 to 6 bolts on the exhaust or compressor backing.
The oil drain should be straight up and down or slightly angle towards the oil pan.
The drain is gravity base so use your brain.
And if you dont got the tool buy one.
Should be a 14 or 15mm
Ok I have loosened all the bolts on the turbine and compressor housings. Problem is the compressor housing wont rotate independently of the center housing.
1 - 12 of 12 Posts
