1 - 2 of 2 Posts
That saying is sure right, When boosted, expect problems, I always have problems.
Was hard to start car, just kept cranking and cranking but wouldn't turn over.
Starts up then I get these CEL codes via Kpro:
Code 17-1 CEL: P500 VSS Malfunction
Daughter Board Communication Error (Battery Voltage Low when Cranking)
P0217 Engine Overheating
yet Temp is at 170
I got the VSS code before. I checked connections and everything is fine. Could it be bad? MPH work fine and stuff.
VSS code will NOT effect starting the motor....
Bad Ground causing a low voltage issue with the K-Pro?
1 - 2 of 2 Posts
